I just noticed that the the bedtime reminder in Mudita Harmony only is activated when the alarm is activated. Basically if I don’t turn the alarm on, then even if the bedtime reminder is on, it will not go off at the set time, unless the alarm is activated. Is this intentional?
@valleygirl Thanks for reaching out. So let me make sure I understand you correctly: there are times when you haven’t activated the alarm yet, or do not plan on activating for the night, but you still want to use the Bedtime Reminder feature- but it does not go off if the alarm is not activated. Is that correct?
It is strange because the bedtime reminder works here, even with the alarm off. Is the Harmony updated?
Never mind- It was all me I wasn’t setting it correctly. Everything works fine.
