Low volume on call (loudspeaker and speaker alike)
Hello,
I’ve been using the phone (global) for 1 year or so and i finally decide to bring this issue up here
I’ve read that some had similar problems but i don’t know how it resolved
I’m always at max volume for calls but when I’m not in a silent setup, I have a hard time understanding my caller wether I m on loudspeaker or on the speakers at my ear
eg. if outside, it difficult to have a conversation
has this problem been diagnosed as a hardware or software issue ?
for alarms or notification, the volume is way higher
on the setting page, the alarm at 30% is louder than the call sound even at max level
Sometimes, it could be a network issue, but to be sure you’d have to reach out to our tech support & give them access to the logs, so they can check what’s happening “under the hood” for this to occur. However, one of our talented Community members created a utility app for Mudita Kompakt that increases the the maximum in-call volume beyond the stock setting.
Check it out: MK Volume+ review by chadp
thank you, i will check it out and reach to the support for them to check if it could be a hardware issue
This is what i meant :
video
I think this might be because alarm sound is coming out of a different speaker- the one on the bottom. Each speaker has a different function. That could be the cause of when you’re experiencing.
everyone have the same experience then doing the same test as in the video linked ? https://www.youtube.com/shorts/eNMUyXuUJcM
Is this a question to the community, in general? Because I have not heard about this comparison before.
I get the same results in the test. “Call volume” is low.
@urszula yes it is a general question
@smuch thank you, so i suppose it s unrelated with my current problem
It is related, and I think you identified a problem with the same call volume problem that I have with my Kompakt phone. It is stressful to hear callers and unsatisfying to use the Kompakt as a phone for conversations for myself and the other person to have to repeat themself.
