Kompakt not connecting to iPhone, kompakt not connecting to data/gps
Bear with me, I’m not the best at explaining. But I’ll do my best.
I’ve connected my iPhone to kompakt. Using the data on my kompakt via hotspotting.
So I can access the internet on my iPhone.: having transferred my sim over.
I’m receiving some texts, although a friend who has an iphone who sends messages which I don’t get back on my kompakt, but receive on my iPhone.; when it’s connected to the internet.
Although the iPhone is connected to the kompakt, the kompakt does not connect to the iPhone. e.g.: I click connect on my kompakt, it says connecting then disconnected.
End of my rope with this one.
Weather isn’t connecting neither is maps.
I’ve lte enabled.
I’m asked to turn on the gps.
So any advice would be appreciated.
I’m having trouble understanding everything you’re saying, but I believe your main point is that the Kompakt’s hotspot doesn’t appear to be working?
If so, I also had an issue where my hotspot wouldn’t work. It turned out that it was an issue with my cellular service provider (US Mobile) and the APN settings on my Kompakt. This Reddit post helped me fix my issue.
I did say I wasn’t good at explaining. :smiley:
However you’ve helped me clarify a few points.
My iPhone connects via hotspot to the kompakt.
Kompakt doesn’t connect to the iPhone.
Sim is in kompakt.
2nd issue.
It seems I cannot connect to the internet using the data of my SIM card on the kompakt.
Maps don’t show up, weather also.
I’m asked to turn on my gps.
I will check out the reference you gave me. Thanks.
@bearto Let me see if I understand you correctly:
This is your working setup:
  • The Kompakt is providing hotspot,
  • The iPhone is connecting to the Kompakt hotspot,
  • The iPhone can use the Kompakt’s mobile data to access the internet.
This part is working as expected. Is this correct?
You also mentioned:
“I’m receiving some texts, although a friend who has an iPhone who sends messages which I don’t get back on my kompakt, but receive on my iPhone.”
This looks to me like classic iMessage hijacking.
This is what I think may be happening (but iPhone users please correct me if I am wrong):
  • When YOU moved YOUR SIM from the iPhone to Kompakt, Apple still thinks YOUR number uses iMessage.
  • Messages from iPhone users get routed to iMessage instead of SMS.
  • Since Kompakt cannot receive iMessage, those messages appear only on the old iPhone, as long as it still has Wi-Fi/data.
Fix: Turn iMessage OFF on the iPhone while the SIM is inside it.
(AND if you want to continue using KOMPAKT SMS only, please make sure to deregister the number from iMessage.)
I’m not sure what you mean by:
“Although the iPhone is connected to the kompakt, the kompakt does not connect to the iPhone.”
You may be misunderstanding normal hotspot behavior.
  • A phone providing hotspot does not need to connect back to the device that is using its hotspot.
  • Are you clicking something on Kompakt & expecting a two-way Bluetooth or Wi-Fi connection.
  • What you’re is seeing (“connecting… disconnected”) is normal because the Kompakt does not connect to the iPhone for internet in this configuration.
You also mentioned that "Weather isn’t connecting neither is maps.”
Are you sure your Mudita Kompakt has data access & you have your locations enabled?
Please note that MAPS will not work properly indoors. Mudita Kompakt has a receive-only GPS, this means that you have to have a clear view of the sky to grab the signal. However, for Weather, you should make sure you’ve enabled location for it to work.
Thank you. What you’ve said makes sense. Re: iMessage etc.
How do I turn on the gps?
So I can access weather and maps when outside?
When connected to the iPhone, I was asked if I wanted to access chats and contacts. When I clicked yes, that’s when it tried to connect but couldn’t.
Maybe it’s a Bluetooth thing.
I’m not tech savvy, however I’m appreciative of your patience.
You need to head to SETTINGS>>>>Location & Sharing
There you enable which apps get to use the GPS.
Ok. Sometimes the most effective solution is the most simple. Thank you.
So I did what was mentioned, and found that I’d already had location and sharing toggled on. I went outside, with a clear view of the sky. Maps asked me to turn on the gps, and weather told me to try again later.
My iPhone connected with the kompakt hotspot, so I could browse the internet.
When connecting to WiFi weather and maps connect is ok.
It is only with mobile data that I have trouble connecting.
I’m thinking of resetting to factory settings, start from scratch.
Such is my conclusion.
I think that’s an option worth considering. This seems to be a mobile data issue- and since your Kompakt has the HOT SPOT & you’re able to use it on other devices that means mobile data is OK.
I reset. And I’ve same issue. In a strange way, the kompakt is not connecting to network data, but my iPhone that is connected to via kompakts hot spot. Does.
It’s an interesting question
Have you made sure your APN settings are set correctly?
How do I check this?
@berto
Which network provider are you using right now?
It looks like you are running into a couple issues:
1 - iMessage still going through your iPhone - Deregister and Turn Off iMessage - Apple Support
2 - Maps and Weather not working - you need to also enable location Sharing to these two apps from the same Location Sharing setting page that urzula pointed at. By default, Don’t share is selected for these apps, even after enabling ‘Use your current location’.
Vodafone. Seems everything on the apn looks correct. Maybe I need to upgrade my sim.
That’s my next step.
Did you finally get the internet to work? My hotspot will also connect to my iPhone, but says no internet connection even though it’s connected. So I cannot access maps or anything on my iPhone either. Not sure what is supposed to be connected. Lol
Is your mobile data on?
I changed sims and went to an eSIM with my service provider. Still no luck. My only other option was to see if a sim from another provider would work. It did. So I changed provider. I had been with Vodafone Ireland. Now I am with 3.
I sometimes face similar issues. I often connect a Samsung Gslaxy Tab A9+ to the Hotspot of Mudita Kompakt, which uses a 1&1 / Vodafone SIM card with LTE tariff. Usually both devices have access to the internet, but it happens from time to time, that the tablet could not connect to the internet but the Kompakt does or opposite. But both devices show internet connection. The Hotspot function is not really stable at the moment.
When I try to Bluetooth connect my iPad to kompakt iPad shows connection to the kompakt, but not the reverse.
