Yes, sideloading stays & you will be able to still sideload via Mudita Center or if you choose, vis command prompts & ADB
@Born2bDeer I have asked our team about your questions when it comes to AI.
When it comes to the removal of apps, are you looking to uninstall the whole InkApps store or just specific apps you have on your phone?
Being able to uninstall the whole InkApps store would be the inquiry.
I did see that the InkApps will be able to manage apps installed on the device.
Thanks much! Appreciate your commitment to letting the user decide on apps and they way can use the phone!
In the launch of MuditaOS K 2.0.0, InkApps will be able to be hidden, but it will not be able to be completely uninstalled through the phone’s native settings. You could have that option if you use a third-party uninstaller app, like Batch-uninstaller (I use that to get rid of apps I don’t use- like CHESS LOL).
Future native removal options are still being discussed.
Will there be a way to stay on Mudita OS without an app store? Part of the reason I got the phone to begin with was because there was no app store. I actually want the added friction of having to sideload the apps.
Also, I’m hoping there will not be any access to install web browsers or anything similar. That would be a show stopper for me.
You’re not obligated to update. You can stay on the version you are on. Also, we are very mindful of the apps that are included in InkApps, so as far as I know, there will not be a browser in InkApps next month.
Ok thanks for the answer to those questions.
What about rollback? Is there a way to rollback to an earlier version of Mudita OS if I decide the app store is not a good fit for me?
Thanks again!
Right now, there is no ability to rollback to a previous MuditaOS K once you update the device. This is something that’s on the team’s radar, but no decision has been made.
