Yesterday,
By updating the maps that are on my MK, I had several time the message that the memory of my phone is full.
After emptying the cache and restarting I could go forward but I had to do that several times till I got all updated.
So I’m thinking to add an SD card to my phone just for the maps.
Question: is there a way to transfer the maps on the SD or will I have to download them again?
That said, the process is very annoying. A button « update all » will be much more convenient.
After
Not sure whether it’s possible to transfer the maps, you can only change the storage location in Maps > Settings > Storage Location. You could try, using the built in file manager (after you changed the storage location to sd card and force closed the Maps app) to move the entire folder Android \ data \ com.Mudita.maps with all folders included to the root of the sdcard. Be carefull not to overwrite things or else start in data or even in com.mudita.maps if in doubt and move them to the sd card. Now reopen maps and see if it works. Worse case scenario, you, you have to download them again. Don’t forget to check if the old storage location is emptied or do it manually to free up some space.
I’m not sure if you can transfer them, but they can be stored on the SD card when you download them.
Yes y I’ve seen that, thanks.
That’s why my question.
Trying to avoid downloading again all the maps.
I wonder if the SD card is inserted then the option to change location to SD card may become active and un-greyed-out?
