Having a lot of issues
My Kompakt has been super buggy and slow recently. I’m totally fine with the e ink speed but sometimes it will just jump between gestures, apps will take like 5 seconds to open or close. Also I cant text people photos, it just stopped working all of a sudden. I didn’t change any settings. Does anyone have any solutions? Feel like this phone should be getting a lot more frequent updates…
@rookang777 Hi thanks for sharing your experience.
Before we jump info troubleshooting can you give us some more info:
What version of MuditaOS K are you currently running?
Any sideloaded apps?
If you don’t have any sideloaded apps. did you, by any chance, sideload apps & then remove them?
Hi urszula, thank you for responding. I have version 1.4.0 the latest version and I do have a bunch of sideloaded apps but it seems like the Mudita stock apps behave the slowest out of any of them. Are there any known sideloaded apps that can slow down the phone overall?
I will ask the team, but from my own knowledge, depending on the sideloaded apps you have, they can have an unintended impact on how the native apps preform.
@rookang777 Go to Developer options → Running services.
See what is using up your RAM.
