Fingerprint scanner and the (manual) working person
Firstly, I’ve tried searching for an answer but to no avail. Is there any way to change the unlock screen from fingerprint scanner to passcode? and change the passcode option to 4 digit? I work with my hands and also skateboard (griptape fingers is a thing) as such my hands are almost always rough and rugged. Because of this i have an absolute NIGHTMARE unlocking my phone with the overly sensitive fingerprint scanner. pressing the button a few times at random will sometimes bring the passcode unlock screen up which i can then use, but there doesn’t seem to be an official way to trigger the passcode screen. I REALLY need an option to use passcode only and not the scanner (again a toggled option for users) as I am CONSTANTLY being locked out of my phone because the scanner fails to recognise my prints. This is a very basic function that you find on literally every device that has fingerprint scanning of face scanning, I don’t understand. why unlock. options were not a user based choice from the start. If anyone does know an official quick way to bring up the passcode screen please let me know.
I have the same problem when my hands are cold, so when the screen with the lock at the bottom shows, because the finger print scanner didn’t work, I just swipe upwards and the passcode unlock screen comes up.
I hear you on the locking frustration :slight_smile:
Since I always have physical control of the phone I set the Screen Lock to off, and Screen Timeout to 30 minutes.
Pressing the side button “locks” and “unlocks” the phone. I mainly use it just as a talking phone.
see:
Yes, swipe also good option - its in settings
@xjezedgex
The pin code is 6 digits. You don’t have to use the fingerprint. You can also use a swipe-up motion.
Go to SETTINGS>>>SECURITY
