When the device is ‘connected’… can you fully disable bluetooth?
As @urszula said, Bluetooth is independent of the Pure modes - you can enable/disable it at any time via settings. Moreover, when Bluetooth is disabled, the Bluetooth module inside the phone is also disabled which means that no RF should be emitted while the BT is turned off.
