Dictionary — Community App Review
Version: 0.1.1
Dictionary is an English dictionary and thesaurus that works without a connection. Select a word in another app, choose Define, and its meaning opens over the app you were in; Back takes you straight back.
Each meaning comes with how the word is said, an example or two, and the words around it: other words for the same meaning, the opposite, words close to it, and the broader word it is a kind of. Every one of those can be pressed to look it up in turn.
When the word was selected in something you are writing, pressing another word offers to put it in place of the one you selected, capitalised the same way. That is the thesaurus.
It finds a word under its endings: ran opens run, geese opens goose, and running shows both running and run.
It has a search field of its own too, with the words that begin with what you have typed and the ones you looked up lately.
About 136,000 words from Open English WordNet 2025. The whole list is inside the app, so nothing leaves the phone, and it asks for no permissions at all, not even the internet.
On the Kompakt, Define sits behind a ⋮ at the end of the selection menu, since the phone’s own selection bar only has room for two or three items. Typewriter, Clippings and Messaging have that ⋮; apps that don’t may not offer Define at all.
Is there a word it gets wrong, or one it can’t find?
