Dear Mudita (bluetooth security)
Dear Mudita Kompakt Team,
Please consider adding an option to customize the device name that is broadcast over Bluetooth.
At work, I prefer to keep a low profile and avoid drawing attention to the specific devices I’m using. Most phones allow users to rename the Bluetooth device to something generic, such as “Phone” or “Cell Phone.” However, when “Kompakt” is displayed, it makes the device immediately identifiable.
I hope this is a simple feature to implement, as it would provide users with more privacy and flexibility.
Has anyone else run into this issue? I’d be interested to hear whether others would find this feature useful as well.
Thank you for your time and consideration.
To change your Mudita Kompakt’s Bluetooth broadcast name:
  1. Sideload a custom launcher: The easiest way to bypass default Android restrictions on the Kompakt is to sideload a text-based, E-Ink-friendly alternative launcher like inkOS or Minimo Launcher via the Mudita Center. [1, 2]
  2. Access full system settings: Once you have a third-party launcher or alternative app drawer installed, you can access the deeper system preferences that are typically hidden by the stock Mudita user interface. [1]
  3. Change the device name: Navigate to Settings > About Phone > Device Name and enter your desired name. This name will now be broadcast to other Bluetooth devices
I have InkOS but I’m confused where to go. can you give me the step by step for inkOS? thank you!
I will pass this on to the team. Thank you for the feedback.
Thank you Urszula, I hope to see it in the next update!
My device running MuditaOS K 1.5.0 doesn’t have menu options you describe. I have “About” instead of “About this phone”. Under “About”, I don’t have “Device name” at all. There is “Device model” but it is not editable.
It doesn’t have that option because that comment from that user is AI generated.
AI suggests that because that works on pretty much any other AOSP phone, just Mudita has disabled the ability to edit the device/bluetooth name. It’s a standard AOSP feature.
If you search “Device name” in developer options both the option to edit the bluetooth name/device name appear but they’re broken (settings will crash if you try to open it).
Guys, @smuch was talking about inkOS, not MuditaOS K. I think none of that reply was AI.
No they weren’t. I made inkOS and there’s no “settings / about phone / device name” inside inkOS.
Cool. (I do not have any other words in my mind).
What a strange hobby for that person. Appreciate you letting me know.
Strange indeed ……. In folklore the :frog: likes the sound of the croak
If you’re familiar with ADB, you can do it via command prompts.
On most Android devices, the Bluetooth name is stored in global settings.
:warning: Just please keep it mind that it can be reset with every MuditaOS K update.
Here’s are the prompts:
adb shell settings get global bluetooth_name
If this returns null , try checking the secure namespace instead:
adb shell settings get secure bluetooth_name
No it actually resets the name back to “Kompakt” on restart.
I know users on this forum ask for all kinds of crap. But fixing the broken bluetooth/device name editor should be a priority. Not something “to be considered” by the team.
And I repeat this is as stock AOSP function, nothing to code, simply style the menus, so they just have to unbreak what they broke.
That’s what I meant- the name will RESET back to KOMPAKT with a factory reset.
I pass this info on to the team. Unfortunately, it’s not up to me. :slight_smile:
Nope, it will reset with a simple restart of the phone (or if your phone turns of because of low battery).
Got it. Thanks for the clarification!
Leave it the default value, hope for a future version fix the Kompakt as an ID this is obscure enough for me. Yes, I apologize the details I provided were not a solution, sorry. There are bigger fish to fry with the Mudita OS.
I google for answers but I do not have a googled device (not an AI reply).
Do you have a Mudita Kompakt?
Also that’s totally something AI would say. :wink:
I noticed that too :joy::joy:
