Diary:
January 29, 7:00 p.m. = 80% charge
January 30, 7:00 p.m. = 65% charge
January 31, 11:00 a.m. = 40% charge
6:00 p.m. = 24% and shows that "there are still 10 hours of use left (? but I would avoid going below 20%)
So I used about 20% of the battery in about 10 hours?
February 1, 8:45 a.m. = 80%
3:20 p.m. = 20% (??)
Why so much now? For a dumb phone, I expect not to have to charge it every day, ideally every 4 days…
Finally, February 2, 5:00 p.m. = 68% and it shows that there are 7 hours left… something has changed compared to January…
I may have caused the change when I sideloaded Mudita Center Signal, an app to manage a Philips toe, which didn’t even work, and a store (by mistake, because I don’t want it on my phone). Having then changed my mind about these apps on my phone, I hid them and wanted to delete them, but I found out that I can’t and that I would have to restore the device to fix it.
My question is whether those apps (two of which I never even used) can consume so much battery power…
There is another problem concerning when the phone is charging.
I put the phone on charge using my power bank and it showed 4 hours until the end of charging. A moment later, I put it on charge using a slow charging plug (maximum 5 volts) and it showed only 1 hour to complete charging.
I IMAGINE IT IS BETTER TO CHARGE IT SLOWLY, BUT I WONDER HOW LONG it would take for a normal full charge cycle.
In fact, when I connected it to the power bank, it was at 20% and it showed that it would take 10 hours to finish charging… that seems a bit too long, and perhaps absurd. Where is the problem?
Would a reset solve these problems?
