Calm Sudoku — Community App Review
Version: v1.0.0
Sudoku app built using MMD to target the Mudita Kompakt
I hope you enjoy Calm Sudoku! Please consider supporting me in my studies: https://buymeacoffee.com/cbaier33
Version: v1.0.0
Review for version v1.0.0
User rating: ★★★★★
Hello topher17,
I’m using Libre Sudoku at the moment, i have tried so many Sudoku apps. It is very nice to see someone creating it finally for the Kompakt.
The previous apps I’ve tried did not generate their puzzles but relied on you to download puzzles, and they had 30-ish puzzles on each difficulty. Again I play a lot, so 30 “Hard” puzzles finishes for me quite quickly.
Does your app feature generated puzzles or a set amount of them?
Hello, thanks for your feedback.
The boards are generated!
Best,
topher17
User rating: ★★★★★
amazing thank you!
User rating: ★★★★★
If you have plans for an update I have some ideas for you;
-Highlight mode: it doesn’t have to be default as if you use pen and paper, you cant highlight the rows and columns of the number or cell you are looking at. But if you are in a shaky environment like a plane, it makes life easier.
-Errors: I lost my first 2 matches not because of my errors, but because simply I thought I pressed the “Notes” button and it was in fact not pressed. When the game simply ends on the 3rd mistake can be frustrating as, you can’t really do mistakes on Sudoku other than not pressing the Notes button. I don’t know how you would tackle this, as you probably know most AppStore apps just start forcing ads on your face, please don’t do that!
-If you back out on a game, there’s no continue, you get a different puzzle. I don’t mind this as much, but could be added.
Lastly, I do not know how much a coffee costs on your part of the world, so hopefully an overpriced Dutch coffee can buy you a coffee there too. Enjoy!
