When wifi is disabled and I try to make a phone call, there is no call tone with “Calling…” displayed on the screen. After about 10s of this, the call ends with “Call Ended” displayed. I’ve confirmed with the intended recipient that they never received any call. I’ve tried restarting my phone and calling again but get the same result. I’m on the US Mobile Dark Star network and OS K 1.6.0.
You may want to write to [email protected] so that Mudita Support can review your Kompakt’s logs.
Did this just start happening now? Or was it always like this? Have you switched carriers recently?
Update: It looks like it was due to VoLTE being disabled. Calling works now with that enabled. I actually couldn’t make or receive any calls without wifi while it was disabled. Voicemails were coming through though.
@lex1 Thanks for the feedback. So, everything is working as it should?
Yup! I must have accidentally turned that off at some point. I did get a technical explanation in email from Michał on the support team. I’ll leave it here as it adds some context.
This behavior indicates that your device is attempting to route voice calls over a cellular LTE connection, but the Voice over LTE (VoLTE) / IMS session is failing to establish with the US Mobile Dark Star (AT&T) network. Because legacy 3G voice networks have been decommissioned, cellular calls require an active VoLTE connection. When Wi-Fi is turned off, the device cannot rely on Wi-Fi Calling, leading to a silent connection attempt that times out after roughly 10 seconds.
