Bugs and random problems
I have been primarily using the Mudita Kompakt now almost exclusively. However I have noticed some issues that are somewhat annoying.
A group text message doesn’t seem to work. For example my wife sent me a text that included other family members and I did not get any of the texts and now my sms on my phone seems to think I have 1 unread message that I cannot make disappear.
Another issue I have that is not so bad, but strange is when I am driving and my phone is connected to the car. The sound for recieving a message is typically a random beep and not my actual alert tone.
Small issues that hopefully can be fixed through updates…
Hi, from what I’ve seen group SMS is on their radar, in the meantime some of the people here workaround in the meantime by sideloading Quik SMS app.
Another bug that would be great if it could fixed, is when people share contacts with you, if the file could be supported and the number could be saved. My current work around is just asking people to share the actual number because I’m making a choice to no longer use a traditional smartphone.
Not sure if this bug has been mentioned but I put my phone on offline mode and when I receive texts the notification stays on the home screen even though I have no unread messages! Bit frustrating to constantly see 8+ unread messages …
@somastudy I’ve asked our team about this. I’ll get back with the answer once they respond.
We are working on implementing group messages, so it’s not a ‘bug’ per se. Our team is working on getting this implemented in a future update.
Any update? The notifications still won’t clear
@somastudy The update is still being worked on. In the meantime, there’s a temporary workaround: check to see if you have any numbers you blocked. The notification is probably for a group message that isn’t showing up due to an aforementioned bug.
There’s also some tips from our community you can try:
