The battery of my Mudita Kompakt is draning, less than 1,5 days of use in standby with very little use. Last night it went from around 70% to 29% in standby. The thing is that I havenāt sideloaded anything so that canāt be the reason why. The only thing that has changed is that Iām travelling and I have turned on the roaming switch in settings. Perhaps there is a bug in managing roaming in the OS? Or has my phone (hardware) an issue?
My Mudita was draining at a surprising rate even though I was not using it. I had used āmapsā and ācameraā - when I āforced offā the apps I had used, the battery drain decreased a lot.
Yeah that sounds about right. I think someone in another thread found that maps was using a lot of network connectivity, which is very strange. This is why I wish the MK had a proper task manager were you could easily see what apps were running and kill the ones you donāt need.
Iāve quit the Maps app and even restarted the device but it doesnāt work ![]()
agreed they should at least implement one that appears when long pressing the home button
@asede Iāve asked the team about this in order to get some feedback on your issue. Letās see what they say.
Thanks!! I left it on Offline+ for the whole night and it only went down only a 1-2%. And today I left it also in Offline+ the whole morning and it went down around a 5-7%. The problem seems to be with roaming, perhaps some process related to roaming running on the background that wasnāt on when I hadnāt turned the roaming switch on because I wasnāt travelling?
Iāve noticed that using LTE instead of Wi-Fi is killing battery the most. As Iām most of a day on Wi-Fi Iām getting 2-3 days with sideloaded Signal and few more apps. But turning the Wi-Fi off and going on LTE makes the battery last for 1 day like a ānormalā smartphone. So my advice is: use Wi-Fi as often as possible.
I have a similar observation.
I havenāt sideloaded any apps. I have turned Wi-Fi off. For an average of 2h of calls and 150 SMS usage, last week I managed to pull 6 and a half days of battery.
Charged the phone on Sunday afternoon. This week twice I had to use hotspot for around 1-2h per day and it killed my battery for less than 3 days.
I imagine if you use mobile data or hotspot all day, the battery will be gone trough the night.
Important update: Iām back home, and with the roaming switch turned off, everything seems to be back to normal; the battery lasts as usual. I consider it important because that means that, as I thought, the problem is in the software when managing roaming, perhaps thereās some process that makes the battery drain so fast. I hope this feedback is useful for the team.
@asede Thank you for the feedback. I will pass it on to the team.
Hello everyone,
Last week I got my new Mudita Kompakt and I hoped for days of battery life. Unfortunately Iām experiencing similar battery life as I did with my smartphone - 1 day. I sideloaded whatsapp and spotify, but Iām not using both apps often. I read the recommendations above and I deactivated roaming and tethering etc. Also I try to use wifi Ć”nd LTE (both of which I thought I could just use normally, but that aside) as little as possible. This doesnāt change a thing. I still get but 1 day of battery life out of my newly bought phone. Does anyone have any other recommendations?
Thanks in adance!
Hi @diovdl. Try to only use LTE for a few days (keep Wifi turned off and never turn it on) and see if that makes a difference?
Just to double check - are you killing Whatsapp and Spotify when not needing them? In Settings > Manage Apps > app > force shutdown I guess thatās how it may be called in English.
@diovdl are these the only 2 apps you sideloaded?
