Will Mudita Pure support audio books?
You could put them onto your Mudita Pure through Mudita Center, and use the Music app to play them, as there is not a dedicated app for audiobooks or podcasts.
Use open audible to convert amazon audiobooks to mp3
You can use AMusicSoft Audible Converter to convert audiobook files to MP3 or other commonly-used formats, such as WAV, M4A, and FLAC. I have been using this for several months. Not only Fast conversion speed but multiple output format choices. There are no guarantees for you that this method will work, but it’s worth a try.
