Air Pods Issues?
I have Airpods Pro 2, and they connect to the phone. However, whenever I make calls, the microphone isn’t working. I have to delete the device, add it as a new bluetooth device, and then it works for calls until I connect them to another device (ie. my macbook air, Apple Watch, etc.). Is there a fix or workaround for this?
I have AirPods 4 with ANC (same H2 chip as yours), multiple devices connected and no issues.
I have Find My disabled and have the latest firmware on them (build 9A348).
Maybe try factory reset on the AirPods (How to reset your AirPods and AirPods Pro - Apple Support).
Thanks for sharing. I wonder if having FInd My enabled is my issue. I’ll try doing a factory reset.
I have AirPods Pro 3 with Find My enabled and I haven’t had any issues - I would also check to make sure your firmware is up to date and try removing and re-adding them in Bluetooth.
Thanks! I’ll give that a try!
This is very interesting. I am not familiar with Apple products, so I would appreciate to hear about the experience of others.
I think Apple’s switching settings are worth investigating, but I’m not sure if there is some unsupported Apple setting that is causing the problem. Apple explicitly supports using AirPods with non-Apple devices for both listening and talking, so the microphone should not require an Apple-only feature.
The useful clue is that re-pairing restores the microphone until the next device switch. That suggests a problem restoring the Bluetooth call connection or audio routing.
Thanks for reaching out. I did a full reset of the airpods and I’m going to see if this helps. I’ve also noticed that the issue occurs if I answer the call on the Kompakt and then try to switch over to Bluetooth mid-call. So perhaps I just need to make the switchover before I take the call. Doesn’t seem like this is an issue for others, so I’ll keep working and see what I can figure out!
