24 Hours Later... Maybe the Kompakt is not for me
I’ve had the Kompakt for a day now, and I want to be upfront: I love the idea of this phone. E-ink, simple, deliberate, not screaming for my attention. That’s why I bought it. But I bought it as a communication device, a replacement for my Pixel 8, and 24 hours in I’m not sure it clears that bar. I only have a week before I have to decide to keep it.
What I needed it to do
Sideloading was the thing that made it plausible for me. WhatsApp, Signal, Spotify, Bitwarden. Those are non-negotiable, and the fact that Kompakt allows them is a real differentiator. Turn-by-turn navigation is the other one. I’m still on pre-1.6, so I haven’t seen the improved Maps setup yet. If it doesn’t work out, I’ll try Organic Maps. No strong opinion there yet.
What’s missing
  • No visual notification. When a WhatsApp/Signal message arrives I hear the notification, but I have no idea what notified me. On a phone built around checking it less, this is backwards. I now have hunt and peck to find out whether it mattered. I’m going to assume that 90% of users have side-loaded some other communication app.
  • SMS vs RCS. Existing threads and messages have gone missing because people are sending me RCS. My only remedy is to contact people one by one and ask them to change how they text me.
  • No password manager / MFA integration. I can pull a password out of Bitwarden, but it’s all manual typing.
  • No per-contact exceptions to silent mode. On the Pixel I can silence everything except my favorites. My kids need to be able to reach me at any hour, full stop. This is the single feature I’d call critical, and I don’t have it.
  • No way to remove a sideloaded app. Seriously?
  • No easy way to kill running apps. Spotify doesn’t need to be running in the background all day.
The bigger thing
I think the Kompakt is trying to do too many things at once. RCS is gone, I’m assuming for security or scope reasons, and yet I can sideload arbitrary Android apps. Those two decisions point in opposite directions. I’d much rather the Kompakt picked one problem: be the best intentional communication device on the market. Right now it falls short of that, for the reasons above.
On timing
Google Calendar sync is on the roadmap for MuditaOS K 2.0 this autumn, which I absolutely need. But Do Not Disturb, the favorites and silent-mode gap that matters most to me, is listed for next year. And the 1.6 rollout had to be temporarily paused for hotfixes, which doesn’t build my confidence that autumn’s 2.0 arrives on time or arrives clean.
So I’m weighing returning this now and coming back in six months, once the quirks are worked out. I’d rather buy it twice that risk keeping it now and hoping for improvements.. Happy to be talked out of it if I’m missing something obvious, and I’m hoping I am.
You could install Katapult launcher. It solves many of the issues you mentioned. This launcher is so good that many of its features will be copied in the upcoming update 2.0. The question is: why copy them, when this great app already exists ?
Second the recommendation for Katapult Launcher - should help with many of your concerns.
Thank you for that, it helps a lot. I’ll give this a go for another 24 hours. Does anyone have recommendations for maps? Should I wait for 1.6? Should I use another external one?
HERE WeGo Maps:
There is also PaperMaps, but it’s still in alpha/beta testing mode:
InkOS or Katapult Launcher by @gezimos will be the solution for most of your problems. Especially Katapult Launcher, but in my honest opinion text based inkOS is much prettier than the Katapult launcher.
For maps again I feel like I’m copying people’s comments but @davidray ‘s PaperMaps is very very good. It will/can not replace Android Auto or CarPlay, but still very good.
@david-ger ‘s KompaktCalendar or again @davidray ‘s PaperCalwndar has Davx5 sync so you can maybe sync your agendas with those. (I managed to sync my work Outlook Agenda to both of these)
Also messaging by @wander is quite good for Signal or overall upgraded look for SMS.
I use KashCal to sync my apple calendar and it works great.
Also a question for the community: I use InkOS because I prefer the aesthetics over Katapult, but I still have the issue OP mentioned of not getting lock screen notifications for WhatsApp, KashCal reminders, or really anything other than texts and missed calls. Is there a way to fix that?
If you have inkOS and Katapult installed, and make inkOS the main launcher, just have the Katapult running in the back. InkOS does not have any lockscreen or screensaver options, just configure them inside the katapult and let it run in the back. You will have the Katapult lockscreen and inkOS on home.
At least this is how I’m running my Kompakt at the moment. I have the Katapult lockscreen and screensaver (I toggle the screensaver with a shortcut on inkOS), but my launcher is inkOS.
RCS issues resolve themselves after a 30 day washout period. It can suck for those 30 days, as you have found. Be sure you unenrolled from RCS within your Pixel’s Messages app settings.
Mudita is committed to the Kompakt being a de-Googled device. Implementing RCS on a de-Googled device is somewhere between “extremely difficult” and “virtually impossible”, though the folks over at GrapheneOS are working on getting it figured out. Suffice to say it would be a monumental undertaking for Mudita’s dev team. Samsung tried and eventually gave up, instead started shipping Samsungs with Google Messages app.
For what its worth, I too feel that the lack of RCS is a major issue, but I’ve decided overall that the phone is a good fit for me.
Seriously consider your needs and allow more time for a transition, it may be easier to adapt to the Kompakt since you are familiar with Android and sideloading apps
My experience, I found minimizing use on the iPhone for specific secure apps and for messaging along with the Kompakt as a call forwarding phone.
I have a week, that’s all they give you to test things out. It’s definitely better with Katapult, but we’ll see how the next day or two go.
The Mudita Kompakt is about mindfulness and mental health - a sane relationship with our phones.
An important part of a sane relationship with your communication device is the absence of all those notifications, especially from social media apps.
Notifications work on the same principle as gambling addiction: a variable ratio reinforcement schedule. When a variable ratio reinforcement schedule is used, compulsive behavior can be generated in even pigeons. (There is a famous B.F. Skinner experiment that did this!)
”Heavy social media engagement mirrors problem gambling patterns, leading to disrupted sleep, compulsive checking, and impaired decision-making pathways in the brain.” - National Institutes of Health
In my personal opinion, loading the Kompakt up with social media apps and notifications and widgets defeats the entire purpose of the device. (Unless the novelty of an e-ink screen and/or seeing just how far the device can be pushed beyond its original intention is the appeal.)
No, it’s not about wanting social media, it’s messaging/communication. I’m not wanting FB, Twitter, Instagram… please read my post. It’s about being a communication device. Please don’t assume that everyone uses a phone like you do, and if they don’t, it’s unhealthy. For example, our Buddhist community here uses WhatsApp to send out updates.
For what it’s worth I too feel your pain:
  • I like the idea of minimalism. Am a huge fan of e-ink technology.
  • Sideloading apps really helps. Bitwarden works better on the Mudita than on my HMD Fusion.
  • Communications, however, is key to me: having islands of groups on RCS, Whatsapp, Signal etc.
Reading through this forum you can see there’s so many options and apps that emulate most of what we get on mainstream Android devices but they are not quite the same. Compromised in one way or another.
The Kompakt is different. A different way to do stuff in 2026. Maybe let’s chat over DM?
Sorry, but write in hurry. Many things You mentioned will be addressed in 2.0 - especially notifications. Even 1.6 is delayed, we do not expect, as for now, any delay of 2.0.
If You wanna keep your device longer that 2 weeks of trial period, it is doable. Please contact our support that you need additional week or two. We are actually considering extending trial period. You may refer to my post here :wink: (but I will inform the support team anyway).
I hope You will like the device, if not, it is also ok. I am really hoping and believing that one day it will meet all your needs;-)
At present I too don’t think I can use the Kompact as my daily driver:
  • NFC payments/clients do not seem available to me in the UK.
  • Not being able to fix the device MAC address, for Wi-Fi, is a really annoyance.
  • The lack of RCS is annoying, but can live with it.
Can’t wait to try K 1.6 or 2.0 :slight_smile:
NFC payments is a pretty big topic. Device is hardware ready, but honestly, now, at Mudita we do not work on any NFC payment solution. We have it on our radar, but much bigger companies don’t address it. I personally happily use traditional credit card;-) ..we thought about dedicated cover with the pocket for physical card. Good idea?
Personally I would love a cover that doubled as a card holder for times when I am going out & bringing my phone with me it would be great to have a cover to pop a card in & save having to bring my wallet. I also like a phone case that completely covers the whole phone so its more tucked away.
Secrid do some lovely card holders & wallets which also block card scanning.
Thank you for taking the time to explain what you need and where Mudita Kompakt is falling short for you. It sounds like you want to keep the parts of your smartphone that make everyday life easier, while leaving behind the parts that compete for your attention. That’s a totally understandable expectation.
The challenge for us, at Mudita, is that “the essentials” look different for everyone. (If you spend any time of this forum, you can read all about it) For one person, it’s calls and texts. For another, it includes Signal, navigation, a password manager, and a calendar. That’s the thinking behind “Minimalist on your terms,” the direction we’re taking with MuditaOS K 2.0, which is launching in November. It’s all about giving people more room to shape their experience around what matters to them.
That also means listening when something creates extra work. Wanting to know which app sent a notification, or to remain reachable by your children while silencing everything else, makes sense within a more intentional approach to using a phone.
I don’t want to suggest or promise that 2.0 will resolve every point you’ve raised, or ask you to keep a device based on future promises. However, as @Michal_Kicinski, mentioned, if you need some extra time, just let us know. If you have any specific questions about MuditaOS K 2.0, please don’t hesitate to ask.
If something essential to you is missing today, we understand why you’d consider returning it and revisiting it later. However, reading through the comments of our other community member, sideloading could be a bridge that could be an option for you until MuditaOS K 2.0 arrives. Your feedback helps us understand where the experience still needs work, and we appreciate you giving Kompakt a thoughtful try.
I say… enable the hardware…. let the ecosystem of developers make use if it (one way or another) :slight_smile:
For example, I saw this on the Kompakt subreddit: https://www.reddit.com/r/MuditaKompakt/comments/1wkrcip/comment/paz7wno/?context=1&screen_view_count=5
… https://walt.is/ could be an option, s/w wise.
